Aller au contenu principal
Photive Hydra Battery Replacement
Ce dont vous avez besoin
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: étape 1, image 1 de 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: étape 2, image 1 de 2 Photive Hydra Battery Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: étape 3, image 1 de 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: étape 4, image 1 de 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: étape 5, image 1 de 2 Photive Hydra Battery Replacement: étape 5, image 2 de 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): étape 6, image 1 de 2 Photive Hydra Battery Replacement, Battery (Prerequisite): étape 6, image 2 de 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: étape 7, image 1 de 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
Matthew Knight
Membre depuis le 02/09/16
246 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 11-3, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 membres
6 tutoriels rédigés
Un commentaire
Great instructions, I replaced the battery and it works fine.
THANKS!
Terry - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 10
Total : 491
