Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Pine64 PinePhone Motherboard Replacement
Ce dont vous avez besoin
    1. Pine64 PinePhone Motherboard Replacement, Place the device facing down: étape 1, image 1 de 2 Pine64 PinePhone Motherboard Replacement, Place the device facing down: étape 1, image 2 de 2
      • Place the device face down on a non-scratch surface.
      • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
      Demander à FixBot
      Ajouter un commentaire
    2. Pine64 PinePhone Motherboard Replacement, Remove the back cover: étape 2, image 1 de 1
      • Using a fingernail pry open the back cover off with the bottom left indent.
      • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
      Demander à FixBot
    1. Pine64 PinePhone Motherboard Replacement, Battery: étape 3, image 1 de 1
      • Using a fingernail, press into the bottom divot and remove the battery from the phone.
      Demander à FixBot
    1. Pine64 PinePhone Motherboard Replacement, Motherboard: étape 4, image 1 de 1
      • Use a spudger or plastic opening tool to pry off the plastic cover.
      Demander à FixBot
    2. Pine64 PinePhone Motherboard Replacement: étape 5, image 1 de 1
      • Use a spudger to lift the ZIF tabs and press-fit connectors free.
      Demander à FixBot
    3. Pine64 PinePhone Motherboard Replacement: étape 6, image 1 de 1
      • Use a spudger to lift the motherboard up and remove it from the device.
      Demander à FixBot
2 autres ont terminé cette réparation.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 42
Total : 1,929
