Aller au contenu principal
Pioneer FH-X730BS Disk Drive Replacement
Ce dont vous avez besoin
  1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: étape 1, image 1 de 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: étape 1, image 2 de 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: étape 1, image 3 de 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Disk Drive Replacement: étape 2, image 1 de 1
    • After removing the stereo face from the frame, it should look similar to this.
  3. Pioneer FH-X730BS Disk Drive Replacement: étape 3, image 1 de 1
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  4. Pioneer FH-X730BS Disk Drive Replacement: étape 4, image 1 de 3 Pioneer FH-X730BS Disk Drive Replacement: étape 4, image 2 de 3 Pioneer FH-X730BS Disk Drive Replacement: étape 4, image 3 de 3
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  5. Pioneer FH-X730BS Disk Drive Replacement: étape 5, image 1 de 3 Pioneer FH-X730BS Disk Drive Replacement: étape 5, image 2 de 3 Pioneer FH-X730BS Disk Drive Replacement: étape 5, image 3 de 3
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
Cody Pesta
Membre depuis le 09/17/18
688 Réputation
6 tutoriels rédigés
Équipe
Washington State, Team S2-G4, Hope Fall 2018 Membre de l'équipe Washington State, Team S2-G4, Hope Fall 2018
WSU-HOPE-F18S2G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 336
