Aller au contenu principal
Pioneer FH-X730BS USB Port Replacement
Ce dont vous avez besoin
  1. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: étape 1, image 1 de 3 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: étape 1, image 2 de 3 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: étape 1, image 3 de 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS USB Port Replacement: étape 2, image 1 de 3 Pioneer FH-X730BS USB Port Replacement: étape 2, image 2 de 3 Pioneer FH-X730BS USB Port Replacement: étape 2, image 3 de 3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS USB Port Replacement: étape 3, image 1 de 3 Pioneer FH-X730BS USB Port Replacement: étape 3, image 2 de 3 Pioneer FH-X730BS USB Port Replacement: étape 3, image 3 de 3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS USB Port Replacement, USB Port: étape 4, image 1 de 1
    • Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • The end of the soldering iron will be hot.
Cody Pesta
Membre depuis le 09/17/18
688 Réputation
6 tutoriels rédigés
Équipe
Washington State, Team S2-G4, Hope Fall 2018 Membre de l'équipe Washington State, Team S2-G4, Hope Fall 2018
WSU-HOPE-F18S2G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,143
