Aller au contenu principal
Pioneer MXT-X366BT Metal Case Replacement
Ce dont vous avez besoin
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: étape 1, image 1 de 2 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: étape 1, image 2 de 2
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: étape 2, image 1 de 1
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: étape 3, image 1 de 1
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: étape 4, image 1 de 2 Pioneer MXT-X366BT Metal Case Replacement: étape 4, image 2 de 2
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: étape 5, image 1 de 1
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: étape 6, image 1 de 1
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: étape 7, image 1 de 1
    • The metal casing is now fully removed.
Blaine Kaiser
Membre depuis le 03/22/18
169 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S17-G7, Blackburne Spring 2018 Membre de l'équipe Sam Houston State, Team S17-G7, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 13
Total : 287
