Aller au contenu principal
Planet Eclipse Etha Battery and Grip Panels Replacement
Ce dont vous avez besoin
  1. Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: étape 1, image 1 de 2 Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: étape 1, image 2 de 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Battery and Grip Panels Replacement: étape 2, image 1 de 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Battery and Grip Panels Replacement: étape 3, image 1 de 2 Planet Eclipse Etha Battery and Grip Panels Replacement: étape 3, image 2 de 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
Jared Olson
Membre depuis le 10/14/14
211 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 1,214
