Aller au contenu principal
Planet Eclipse Etha Bolt O-rings Replacement
Ce dont vous avez besoin
  1. Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: étape 1, image 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: étape 1, image 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: étape 1, image 3 de 3
    • Using the 1/4" hex key, turn the bolt counterclockwise and remove.
  2. Planet Eclipse Etha Bolt O-rings Replacement: étape 2, image 1 de 2 Planet Eclipse Etha Bolt O-rings Replacement: étape 2, image 2 de 2
    • Slide the bolt tip and spring off of the main assembly.
    • Keep a towel handy, you may get some grease on your hands.
  3. Planet Eclipse Etha Bolt O-rings Replacement: étape 3, image 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 3, image 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 3, image 3 de 3
    • Unscrew the casing from the rest of the bolt.
    • Again, you may get some grease on your hands during this step.
  4. Planet Eclipse Etha Bolt O-rings Replacement: étape 4, image 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 4, image 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 4, image 3 de 3
    • Grab the flat surface shown.
    • Unscrew this portion counter clockwise to remove it.
    • If you're having trouble unscrewing the part, try using a small wrench.
  5. Planet Eclipse Etha Bolt O-rings Replacement: étape 5, image 1 de 2 Planet Eclipse Etha Bolt O-rings Replacement: étape 5, image 2 de 2
    • Grab the threaded cover and slide it away from the spring.
    • The bolt should now be in three pieces.
    • The threaded cover is the same part that you unscrewed in the last step.
  6. Planet Eclipse Etha Bolt O-rings Replacement: étape 6, image 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 6, image 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 6, image 3 de 3
    • Replace and lubricate the 9 marked O-rings.
    • O-ring removal will be explained in the next step.
  7. Planet Eclipse Etha Bolt O-rings Replacement: étape 7, image 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 7, image 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: étape 7, image 3 de 3
    • Grab the O-ring on the sides.
    • Pinch the O-ring upwards to create a gap between the metal and the ring.
    • Use a small object to slip into the loop and pull the O-ring off gently.
    • We recommend using a small Allen Key for this.
nicholasj6
Membre depuis le 10/14/14
261 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 30
Total : 2,174
