Aller au contenu principal
Planet Eclipse Etha Solenoid Replacement
Ce dont vous avez besoin
  1. Planet Eclipse Etha Solenoid Replacement, Regulator: étape 1, image 1 de 2 Planet Eclipse Etha Solenoid Replacement, Regulator: étape 1, image 2 de 2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Solenoid Replacement: étape 2, image 1 de 2 Planet Eclipse Etha Solenoid Replacement: étape 2, image 2 de 2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: étape 3, image 1 de 2 Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: étape 3, image 2 de 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Planet Eclipse Etha Solenoid Replacement: étape 4, image 1 de 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Planet Eclipse Etha Solenoid Replacement: étape 5, image 1 de 2 Planet Eclipse Etha Solenoid Replacement: étape 5, image 2 de 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Planet Eclipse Etha Solenoid Replacement, Frame: étape 6, image 1 de 2 Planet Eclipse Etha Solenoid Replacement, Frame: étape 6, image 2 de 2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Planet Eclipse Etha Solenoid Replacement: étape 7, image 1 de 2 Planet Eclipse Etha Solenoid Replacement: étape 7, image 2 de 2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Planet Eclipse Etha Solenoid Replacement: étape 8, image 1 de 1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  9. Planet Eclipse Etha Solenoid Replacement, Solenoid: étape 9, image 1 de 2 Planet Eclipse Etha Solenoid Replacement, Solenoid: étape 9, image 2 de 2
    • Remove the two black hex bolts that connect the solenoid mount to the body.
    • Use the 5/64" Allen Key to rotate each screw counter clockwise.
  10. Planet Eclipse Etha Solenoid Replacement: étape 10, image 1 de 2 Planet Eclipse Etha Solenoid Replacement: étape 10, image 2 de 2
    • Remove the two Phillips head screws that connect the solenoid to its mount.
    • Use a Phillip's head screwdriver and rotate each screw counter clockwise.
    • Do not attempt to dismantle the solenoid. Intentionally dismantling or tampering with the solenoid voids the manufacturer’s warranty.
Austin Eslinger
Membre depuis le 10/14/14
110 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-42, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 membres
7 tutoriels rédigés
3 commentaires
Watis the price on etha solenoid, where can i get one , l ma staying in SA, myne is leaking ear,email ratgonefishing @gmail. Com
Roelof Koekemoer - Réponse
Hi my etha solenoid leaks ear,where do l get one,wats the price,i m staying in SA
Hello if it’s leaking try to lubricate your O-rings and switch out the filter, these can be very expensive from $55-$99 they don’t Make this model anymore so it’s very hard to find
Eddie -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 2,452
