Aller au contenu principal
Planet Eclipse Etha Trigger Replacement
Ce dont vous avez besoin
  1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: étape 1, image 1 de 2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: étape 1, image 2 de 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Trigger Replacement: étape 2, image 1 de 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Trigger Replacement: étape 3, image 1 de 2 Planet Eclipse Etha Trigger Replacement: étape 3, image 2 de 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Planet Eclipse Etha Trigger Replacement, Trigger: étape 4, image 1 de 1
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Planet Eclipse Etha Trigger Replacement: étape 5, image 1 de 1
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Planet Eclipse Etha Trigger Replacement: étape 6, image 1 de 2 Planet Eclipse Etha Trigger Replacement: étape 6, image 2 de 2
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
Evan Hench
Membre depuis le 10/19/14
211 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-42, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 10
Total : 936
