Introduction
This replacement is necessary if the gasket needs replacement.
Outils
Pièces
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
Remove the solenoid.
Locate the solenoid gasket manifold, underneath the top half of the body.
Presque terminé !
