Aller au contenu principal
Plantronics CS50 Headset Motherboard of the Base Unit Replacement
Ce dont vous avez besoin
  1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: étape 1, image 1 de 2 Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: étape 1, image 2 de 2
    • Flip over the base unit to reveal the bottom.
  2. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 2, image 1 de 2 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 2, image 2 de 2
    • Using a #0 screwdriver, remove the two 2.50mm screws.
  3. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 3, image 1 de 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 3, image 2 de 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 3, image 3 de 3
    • Separate, but do not remove, the silver upper piece from the dark lower piece.
    • Carefully disconnect the wires from the motherboard.
    • Remove the silver top of the base.
  4. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 4, image 1 de 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 4, image 2 de 3 Plantronics CS50 Headset Motherboard of the Base Unit Replacement: étape 4, image 3 de 3
    • Remove the motherboard from the base
Bryan Clark
Membre depuis le 04/12/12
45 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-29, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 1,057
