Introduction
The following steps will teach you how to disassemble your headset and install a new speaker.
Ce dont vous avez besoin
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
Apply additional heat at the tip of the microphone.
Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
Using a plastic opening tool, prop open the edges.
Gently pull the black speaker casing up to remove it.
Use the heat gun to melt the adhesive that holds the bottom of the casing.
Use the plastic opening tool to remove the bottom of the casing.
To reassemble your device, follow these instructions in reverse order. Replace the glue and solder where they are needed.
