Introduction
This guide will teach the reader how to install a new case of the camera. If the case on the camera gets cracked or is starting to come apart, this guide will help to replace it with a new case.
Pièces
Aucune pièce nécessaire.
  1. Flip the camera over so the bottom is facing you.
    • Flip the camera over so the bottom is facing you.
  2. Open the cover on the bottom by sliding it in the direction of the arrow.
    • Open the cover on the bottom by sliding it in the direction of the arrow.
    • Remove the batteries by pulling up on the top with your fingers.
    • Unless otherwise stated, use a phillips #00 screwdriver to remove screws.
    • Remove the two 4.70mm screws in the bottom of the plastic casing.
    • Remove the four 4.70mm screws in the left side of the camera.
    • Now on the side with the strap, remove the other four 4.70mm screws.
    • Use your thumbs to pry the case apart.
    • It is easiest to pry to case apart if your start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a tool such as a Spudger or Plastic Opening tool.
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of case about half an inch. This may be difficult and force is necessary.
    • While pulling the camera out of the case, note the small soft plastic cover on the side of the camera. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out about an inch and a half, pull the device out completely.
    • When completely removing the device from the case, use a firm grasp with your hands for stability and control.
Clay Young
Membre depuis le 04/04/2012
215 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-13, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-13, Forte Spring 2012
CPSU-FORTE-S12S15G13
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 1,310
