Aller au contenu principal
HP Photosmart 935 Plastic Casing Replacement
Ce dont vous avez besoin
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: étape 1, image 1 de 2 HP Photosmart 935 Plastic Casing Replacement, Batteries: étape 1, image 2 de 2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: étape 3, image 1 de 2 HP Photosmart 935 Plastic Casing Replacement: étape 3, image 2 de 2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: étape 4, image 1 de 1
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: étape 5, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: étape 6, image 1 de 2 HP Photosmart 935 Plastic Casing Replacement: étape 6, image 2 de 2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: étape 7, image 1 de 2 HP Photosmart 935 Plastic Casing Replacement: étape 7, image 2 de 2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: étape 8, image 1 de 3 HP Photosmart 935 Plastic Casing Replacement: étape 8, image 2 de 3 HP Photosmart 935 Plastic Casing Replacement: étape 8, image 3 de 3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: étape 9, image 1 de 1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: étape 10, image 1 de 2 HP Photosmart 935 Plastic Casing Replacement: étape 10, image 2 de 2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
Clay Young
Membre depuis le 04/04/12
233 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-13, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-13, Forte Spring 2012
CPSU-FORTE-S12S15G13
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,727
