Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Plastic Zipper Tooth Replacement
Ce dont vous avez besoin
  1. Plastic Zipper Tooth Replacement, Gather the materials: étape 1, image 1 de 3 Plastic Zipper Tooth Replacement, Gather the materials: étape 1, image 2 de 3 Plastic Zipper Tooth Replacement, Gather the materials: étape 1, image 3 de 3
    • This repair requires:
    • YKK Revived Replacement Pliers
    • YKK Revived Replacement Set Plate
    • YKK Revived Replacement Teeth
    • Note: While the replacement teeth are metal, they're designed to replace plastic teeth.
    • Reference the Zipper Identification guide to confirm the appropriate zipper type and size. The set plate and replacement teeth are currently only compatible with #5VS zippers which are non-coated, size 5, with plastic teeth.
  2. Plastic Zipper Tooth Replacement, Locate the missing teeth: étape 2, image 1 de 3 Plastic Zipper Tooth Replacement, Locate the missing teeth: étape 2, image 2 de 3 Plastic Zipper Tooth Replacement, Locate the missing teeth: étape 2, image 3 de 3
    • Unzip the zipper.
    • Double check that there are no other issues with the zipper line, like a missing box, a damaged pin, or torn tape.
    • Locate the area(s) on the zipper tape where teeth are missing.
    • Check both sides of the zipper tape.
    • If more than 3 consecutive teeth are damaged or missing, a full zipper line replacement is required.
  3. Plastic Zipper Tooth Replacement, Remove any damaged teeth: étape 3, image 1 de 2 Plastic Zipper Tooth Replacement, Remove any damaged teeth: étape 3, image 2 de 2
    • Check the teeth adjacent to the voided area.
    • If a tooth is damaged, use end cutting nippers to remove the damaged tooth from the tape by snipping along the edge of the tooth, then peeling the rest of the tooth away from the tape.
  4. Plastic Zipper Tooth Replacement, Replace the zipper slider: étape 4, image 1 de 3 Plastic Zipper Tooth Replacement, Replace the zipper slider: étape 4, image 2 de 3 Plastic Zipper Tooth Replacement, Replace the zipper slider: étape 4, image 3 de 3
    • Check the existing zipper slider:
    • If the slider is still in place, move to the next step.
    • If the slider is missing, and there are missing teeth on the box side of the zipper line, use any voided area on the zipper line to place a new slider onto the track. Then move on to the next step.
    • If the slider is missing, and no teeth are missing or damaged on the box side of the zipper line, follow the Plastic Tooth Zipper Slider Replacement guide. Then move on to the next step.
  5. Plastic Zipper Tooth Replacement, Place the replacement tooth: étape 5, image 1 de 2 Plastic Zipper Tooth Replacement, Place the replacement tooth: étape 5, image 2 de 2
    • Align a single replacement tooth onto the zipper tape beside an existing undamaged plastic tooth.
    • The tooth should sit on the edge cord of the zipper tape.
    • If the zipper needs multiple replacement teeth, each tooth must be set individually, starting with a tooth adjacent to an undamaged tooth.
  6. Plastic Zipper Tooth Replacement, Align the set plate: étape 6, image 1 de 3 Plastic Zipper Tooth Replacement, Align the set plate: étape 6, image 2 de 3 Plastic Zipper Tooth Replacement, Align the set plate: étape 6, image 3 de 3
    • Open the set plate and slide it under the zipper teeth so the replacement tooth sits in the marked groove at the edge of the set plate.
    • Close the set plate and position the pliers into the horizontal indent in the center of the set plate.
    • Crimp the replacement tooth by squeezing the pliers firmly.
  7. Plastic Zipper Tooth Replacement, Repeat: étape 7, image 1 de 3 Plastic Zipper Tooth Replacement, Repeat: étape 7, image 2 de 3 Plastic Zipper Tooth Replacement, Repeat: étape 7, image 3 de 3
    • Repeat the previous two steps for any additional missing teeth.
    • Plan the order of replacements so each tooth is installed next to an existing or newly replaced tooth.
    • Reminder: This should only be done on an area with 3 or less teeth missing. If more than 3 teeth are missing, a full zipper line replacement is required.
  8. Plastic Zipper Tooth Replacement, Variations: étape 8, image 1 de 2 Plastic Zipper Tooth Replacement, Variations: étape 8, image 2 de 2
    • To install teeth close to other zipper parts such as the box or pin, follow the previous steps while carefully placing the set plate away from the part.
    • It may not be possible to set teeth close to the top or bottom stops on pocket zippers.
  9. Plastic Zipper Tooth Replacement, Functionality test: étape 9, image 1 de 2 Plastic Zipper Tooth Replacement, Functionality test: étape 9, image 2 de 2
    • Zip up the previously damaged zipper line.
    • Pull horizontally on either side of the garment to check if the zipper splits.
    • With the zipper closed, check that the newly installed teeth properly align with the teeth on the other side of the zipper.
  10. Plastic Zipper Tooth Replacement, Quality control: étape 10, image 1 de 3 Plastic Zipper Tooth Replacement, Quality control: étape 10, image 2 de 3 Plastic Zipper Tooth Replacement, Quality control: étape 10, image 3 de 3
    • Make a final check to ensure that the zipper slider moves smoothly over the replacement teeth:
    • Tooth is Loose: Tooth isn't firmly adhered to zipper tape and wiggles when touched.
    • Not Enough Pressure: Tooth sits firmly and doesn't wiggle, but the tooth is too thick so the slider doesn't glide smoothly over replacement teeth.
    • In both cases, reapply the rig and apply firm pressure until the tooth doesn't wiggle and the slider moves smoothly over it.
    • If available, use a set of calipers to ensure that the height of the replacement tooth is the same as the existing teeth.
  11. Plastic Zipper Tooth Replacement, Troubleshooting: étape 11, image 1 de 1
    • Variations: There are many varieties of plastic tooth zippers, including different sizes and shapes of sliders and teeth. Currently, YKK only provides replacement teeth and tools for #5VS zippers.
    • Missing Zipper Sliders: If the zipper slider is missing, replace the slider prior to replacing any teeth. Test the slider to ensure that it's the appropriate size and style for the item.
    • Pocket: Pocket zipper teeth can also be replaced with this process as long as the teeth of the zipper are #5VS. However, replacing teeth next to bottom and top stops may not be possible due to the set plate's shape.
Ligne d'arrivée
Sabrina K
Membre depuis le 12/18/24
806 Réputation
4 tutoriels rédigés
Équipe
Patagonia Membre de l'équipe Patagonia
Community
9 membres
138 tutoriels rédigés
2 commentaires de tutoriel
Where can I buy tools and spare parts?
Carlo Semenzato - Réponse
Hey Carlo! If you have a repair business, you can order these tools through YKK's wholesale accounts. But I don't think they are available to home users just yet!
Clara Redwood -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 29
7 derniers jours : 205
30 derniers jours : 1,024
Total : 4,189
