Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement
Ce dont vous avez besoin
  1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement, L/R Trigger and Shoulder Buttons: étape 1, image 1 de 3 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement, L/R Trigger and Shoulder Buttons: étape 1, image 2 de 3 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement, L/R Trigger and Shoulder Buttons: étape 1, image 3 de 3
    • Place the controller face-down on a solid surface.
    • Remove the six screws from the back cover using a Phillips #00 screwdriver.
    • Gently remove both covers away from each other and place in a safe area.
    Demander à FixBot
    Ajouter un commentaire
  2. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 2, image 1 de 3 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 2, image 2 de 3 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 2, image 3 de 3
    • Grab the back cover of the controller.
    • Gently push the shoulder buttons down and out to remove them from their socket.
    Demander à FixBot
  3. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 3, image 1 de 3 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 3, image 2 de 3 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 3, image 3 de 3
    • Grab your replacement shoulder buttons.
    • Slide them under the socket and push them up into the sockets.
    • Be gentle as excessive force can cause damage to them.
    • You'll hear a small click to secure them in place. Test the buttons so they don't fall out of place accidentally.
    Demander à FixBot
  4. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 4, image 1 de 2 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 4, image 2 de 2
    • Grab the front cover.
    • Push the L1 and R1 buttons down and away from the cover.
    • This will remove the buttons in place.
    • Often when you go to put the case back together, the rubber pads for the L1/R1 buttons get scrunched out the place. Instead of putting those buttons in before putting the case together. leave them off. Once you have the case back together, you can snap them in from the outside.
    Demander à FixBot
  5. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 5, image 1 de 1
    • Connect both covers together and replace the screws using a Phillips #00 screwdriver.
    Demander à FixBot
  6. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 6, image 1 de 2 PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: étape 6, image 2 de 2
    • Take your replacement L1 and L2 buttons.
    • Don't excessively press down the buttons as they can get stuck on the side.
    • Gently press them inside the sockets.
    • Press the buttons repeatedly to make sure they are placed correctly so you don't have any issues with them.
    Demander à FixBot
Test your buttons out. If it feels loose or unresponsive you can repeat the process and ensure the buttons are in place.
Miguel Aguirre
Membre depuis le 10/25/23
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-1, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 4-1, Kershman Fall 2023
CSULA-KERSHMAN-F23S4G1
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 32
30 derniers jours : 163
Total : 3,495
