Introduction
Follow this guide to replace the motherboard of the PlayStation 2 Slimline and apply a new thermal pad.
Ce dont vous avez besoin
Turn off your PlayStation 2 and remove the disc and Memory Card.
Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
Remove seven Phillips #0 screws from the motherboard.
Lift up both the mainboard and EMI shield from the case by lifting up the rear edge first.
Remove the old thermal pad from the processor using a spudger and some isopropyl alcohol.
Remove any residues of the old thermal pad from the processor and the EMI shield with some isopropyl alcohol.
Cut out a piece of thermal pad with 0,5 mm of thickness (20 mil) and the dimensions of 3 cm × 3 cm (1.2 in × 1.2 in).
Remove the film from one side of the thermal pad.
Place the thermal pad on the processor and press it down a little to make sure it sticks.
Remove the remaining film from the thermal pad.
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
MrJulian nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
Omg... thank you soo much, i really need this tutorial to change my ps2 slim 90000 thermal pad, thank you very much 😭😭😭
