Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre PlayStation 2 Slimline, utilisez notre manuel de réparation.
  1. PlayStation 2 Slimline Teardown/Disassembly, PlayStation 2 Slimline Teardown/Disassembly: étape 1, image 1 de 3 PlayStation 2 Slimline Teardown/Disassembly, PlayStation 2 Slimline Teardown/Disassembly: étape 1, image 2 de 3 PlayStation 2 Slimline Teardown/Disassembly, PlayStation 2 Slimline Teardown/Disassembly: étape 1, image 3 de 3
    • On a flat working surface, flip the PlayStation 2 Slimline so that the bottom side is facing up.
    • Remove the covers over the screws, circled in red on the second image.
    • Take a Phillip's #1 screwdriver and remove the five screws circled in red on the second image.
    • You will have to remove the "Do Not Void" seal in order to remove the last screw.
  2. PlayStation 2 Slimline Teardown/Disassembly: étape 2, image 1 de 2 PlayStation 2 Slimline Teardown/Disassembly: étape 2, image 2 de 2
    • Make sure you haven't forgotten the screw under the "Do Not Void" seal.
    • Take a metal spudger and separate the upper half of the chasis from the lower half.
    • For later models the DVD drive assembly is not screwed in and will fall off if you open it upside down.
  3. PlayStation 2 Slimline Teardown/Disassembly: étape 3, image 1 de 3 PlayStation 2 Slimline Teardown/Disassembly: étape 3, image 2 de 3 PlayStation 2 Slimline Teardown/Disassembly: étape 3, image 3 de 3
    • With the chassis open you can see the motherboard and its attachments.
    • Identify the battery, then use a spudger to pry it out. Disconnect the battery from the motherboard with your hands.
  4. PlayStation 2 Slimline Teardown/Disassembly: étape 4, image 1 de 3 PlayStation 2 Slimline Teardown/Disassembly: étape 4, image 2 de 3 PlayStation 2 Slimline Teardown/Disassembly: étape 4, image 3 de 3
    • Gently disconnect the three ribbon cables.
    • Take a Phillips #1 screwdriver and remove the four screws on the optical drive.
    • Two of the screws can't be seen on the picture, they are located on the opisite side from the visable ones.
    • Pull up the optical drive and carefully peel the flex cable, attached underneath the drive, from the metal plate.
  5. PlayStation 2 Slimline Teardown/Disassembly: étape 5, image 1 de 2 PlayStation 2 Slimline Teardown/Disassembly: étape 5, image 2 de 2
    • Remove the three PH00 screws from the fan's cover.
    • Then peel the duct tape back and remove the cable.
  6. PlayStation 2 Slimline Teardown/Disassembly: étape 6, image 1 de 3 PlayStation 2 Slimline Teardown/Disassembly: étape 6, image 2 de 3 PlayStation 2 Slimline Teardown/Disassembly: étape 6, image 3 de 3
    • Remove the four screws marked on the picture. These are located on the bottom side of the motherboard.
    • Then flip the motherboard back over and remove the two rating screws on the upside.
    • Now both metal plates should be ready to remove.
  7. PlayStation 2 Slimline Teardown/Disassembly: étape 7, image 1 de 2 PlayStation 2 Slimline Teardown/Disassembly: étape 7, image 2 de 2
    • Remove the metal plate from the bottom side of the motherboard.
    • Now everything should be disconnected and you successfully torn your PlayStation 2 Slimline down.
    • To reassemble, follow these steps in reverse.
tlroesner
Membre depuis le 05/13/12
1 864 Réputation
4 tutoriels rédigés
2 commentaires
not all slimlines are internally the same. as seen in the second picture, this teardown is for the 75004 model
Roman - Réponse
Komponen kotak hitam kaki 4 itu apa gan, di dalemnya kaya jumperan gitu. Itu fungsinya buat apa ya? Posisinya sudut kiri bawah iptikal drive.
camxmovie - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 18
7 derniers jours : 166
30 derniers jours : 735
Total : 77,043
