Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PlayStation 2 Top Cover Replacement
Ce dont vous avez besoin
  1. PlayStation 2 Top Cover Replacement, Top Cover: étape 1, image 1 de 3 PlayStation 2 Top Cover Replacement, Top Cover: étape 1, image 2 de 3 PlayStation 2 Top Cover Replacement, Top Cover: étape 1, image 3 de 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Demander à FixBot
  2. PlayStation 2 Top Cover Replacement: étape 2, image 1 de 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
    Demander à FixBot
  3. PlayStation 2 Top Cover Replacement: étape 3, image 1 de 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
    Demander à FixBot
  4. PlayStation 2 Top Cover Replacement: étape 4, image 1 de 2 PlayStation 2 Top Cover Replacement: étape 4, image 2 de 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    Demander à FixBot
35 autres ont terminé cette réparation.
jwyoung
Membre depuis le 11/04/09
3 178 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 19-1, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 membres
35 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 41
30 derniers jours : 245
Total : 24,289
