Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to replace the AC socket and its cables connected to the power supply.
  1. Turn the PS3 over and lay it on its backside.
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  6. Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  7. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  8. Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  9. Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  10. Lift the power supply upward from its left edge as viewed from the front of the PS3.
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  11. Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture. Remove the power supply from the PS3, minding any cables that may get caught.
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  12. Lift the AC inlet cables straight upward to remove the AC inlet from the lower case. Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
    • Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
21 autre(s) ont terminé cette réparation.
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 61
Total : 21,688
