Aller au contenu principal
PlayStation 3 Slim Top Cover Replacement
Ce dont vous avez besoin
  1. PlayStation 3 Slim Top Cover Replacement, Top Cover: étape 1, image 1 de 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Top Cover Replacement: étape 2, image 1 de 2 PlayStation 3 Slim Top Cover Replacement: étape 2, image 2 de 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Top Cover Replacement: étape 3, image 1 de 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Top Cover Replacement: étape 4, image 1 de 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Top Cover Replacement: étape 5, image 1 de 2 PlayStation 3 Slim Top Cover Replacement: étape 5, image 2 de 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
92 autres ont terminé cette réparation.
2 commentaires
No good mine a Sony.
james register - Réponse
Thank you this helped me so much!!!!
Megan Davis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 89
30 derniers jours : 324
Total : 73,297
