Introduction
If you are replacing the power supply unit, that means that the device is not reliably receiving power and therefore is not operating properly. Before you begin this guide, make sure that you have the proper tools (as listed below), some free time, and a clean and clutter-free space to work. When following the steps to this guide, be sure to be gentle when applying pressure to different panels or components as they may bend or break easily. Otherwise, take your time and make sure to read the steps carefully as you work through your power supply replacement!
Ce dont vous avez besoin
Remove the side HDD bay cover by sliding the panel towards the back of the device.
On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
Slide the panel to the left to unlatch the rest of the hooks.
Install the replacement power supply unit. To reassemble your device, follow these instructions in reverse order.
22 autres ont terminé cette réparation.
8 commentaires
Perfect how to guide. Fixed my PS3 easily. Thanks
Great guide. However, still no power on PS3. Any suggestions as to what else may be the problem?
Peter Maher, I am in the same boat. I have no idea what the problem is. Red light in standby, but as soon as I try to power on, nothing. Same as before I did this power supply replacement. Obviously, something else is the problem. Anyone who has some insight into this please help!
Did you guys get word on the red light with no power on fix mine has the same issue.
i have the same problem as Peter Maher, the red light is in standby neither turning green on pressing nor it sounds beep on long press. dont know whats wrong. anyone has any solution to this?
