Introduction
In this guide we are going to disassemble a playstation 3 controller.
Pièces
Aucune pièce nécessaire.
Remove the five 7.2 mm Phillips screws at the back of the controller. Remove the five 7.2 mm Phillips screws at the back of the controller. Remove the five 7.2 mm Phillips screws at the back of the controller.
  • Remove the five 7.2 mm Phillips screws at the back of the controller.
Ajouter un commentaire
Separate the bottom case from the upper part. All the electronics stay in the upper part. Separate the bottom case from the upper part. All the electronics stay in the upper part.
  • Separate the bottom case from the upper part. All the electronics stay in the upper part.
Remove the left and right bumper buttons (L1, L2, R1 and R2). Remove the left and right bumper buttons (L1, L2, R1 and R2). Remove the left and right bumper buttons (L1, L2, R1 and R2).
  • Remove the left and right bumper buttons (L1, L2, R1 and R2).
Remove the rubber underlays of the buttons L1, L2, R1 and R2.
  • Remove the rubber underlays of the buttons L1, L2, R1 and R2.
Take the battery off the  PCB (printed circuit board).
  • Take the battery off the PCB (printed circuit board).
  • The battery sticks to the PCB through a sticking black surface.
Unscrew the remaining 7.2 mm Phillips screw from the PCB.
  • Unscrew the remaining 7.2 mm Phillips screw from the PCB.
  • All screws are the same.
Take the vibrating components out.
  • Take the vibrating components out.
Unplug the battery from the PCB by using a pair of pliers as shown in the photo.
  • Unplug the battery from the PCB by using a pair of pliers as shown in the photo.
Take the motherboard (PCB) out of the plastic controller case. Take the motherboard (PCB) out of the plastic controller case.
  • Take the motherboard (PCB) out of the plastic controller case.
Remove all loose parts from the body. (Consisting of white rubber button underlays, black plastic buttons and a black rubber underlay for the start and select button.) Remove all loose parts from the body. (Consisting of white rubber button underlays, black plastic buttons and a black rubber underlay for the start and select button.) Remove all loose parts from the body. (Consisting of white rubber button underlays, black plastic buttons and a black rubber underlay for the start and select button.)
  • Remove all loose parts from the body. (Consisting of white rubber button underlays, black plastic buttons and a black rubber underlay for the start and select button.)
Remove the transparent plastic part covering the LED-lights by taking it out with a pair of pliers.
  • Remove the transparent plastic part covering the LED-lights by taking it out with a pair of pliers.
Pull the joy sticks out.
  • Pull the joy sticks out.
Remove the thin flexible green PCB by pulling out the black plastic circuit board cover, relatively in the middle  the motherboard (the hard PCB) and by pressing  click fingers on top of the motherboard. Remove the thin flexible green PCB by pulling out the black plastic circuit board cover, relatively in the middle  the motherboard (the hard PCB) and by pressing  click fingers on top of the motherboard. Remove the thin flexible green PCB by pulling out the black plastic circuit board cover, relatively in the middle  the motherboard (the hard PCB) and by pressing  click fingers on top of the motherboard.
  • Remove the thin flexible green PCB by pulling out the black plastic circuit board cover, relatively in the middle the motherboard (the hard PCB) and by pressing click fingers on top of the motherboard.
Remove the thin flexible green PCB  by lifting and pushing the two  outer flaps.
  • Remove the thin flexible green PCB by lifting and pushing the two outer flaps.
Irene van Heijningen
Membre depuis le 07/03/2018
264 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 63
