Aller au contenu principal
PlayStation 4 Power Supply Replacement
Ce dont vous avez besoin
  1. PlayStation 4 Power Supply Replacement, Flip over the PS4: étape 1, image 1 de 1
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PlayStation 4 Power Supply Replacement, Remove the warranty stickers: étape 2, image 1 de 3 PlayStation 4 Power Supply Replacement, Remove the warranty stickers: étape 2, image 2 de 3 PlayStation 4 Power Supply Replacement, Remove the warranty stickers: étape 2, image 3 de 3
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PlayStation 4 Power Supply Replacement, Remove the plastic screw covers: étape 3, image 1 de 2 PlayStation 4 Power Supply Replacement, Remove the plastic screw covers: étape 3, image 2 de 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PlayStation 4 Power Supply Replacement, Remove the rear case screws: étape 4, image 1 de 2 PlayStation 4 Power Supply Replacement, Remove the rear case screws: étape 4, image 2 de 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PlayStation 4 Power Supply Replacement, Remove the lower case: étape 5, image 1 de 2 PlayStation 4 Power Supply Replacement, Remove the lower case: étape 5, image 2 de 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PlayStation 4 Power Supply Replacement: étape 6, image 1 de 2 PlayStation 4 Power Supply Replacement: étape 6, image 2 de 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PlayStation 4 Power Supply Replacement, Remove the power supply unit: étape 7, image 1 de 2 PlayStation 4 Power Supply Replacement, Remove the power supply unit: étape 7, image 2 de 2
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  8. PlayStation 4 Power Supply Replacement: étape 8, image 1 de 3 PlayStation 4 Power Supply Replacement: étape 8, image 2 de 3 PlayStation 4 Power Supply Replacement: étape 8, image 3 de 3
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
190 autres ont terminé cette réparation.
Sam Omiotek
Membre depuis le 02/25/19
72 595 Réputation
288 tutoriels rédigés
69 commentaires
Gonna do this tomorrow, I'm just hoping this is what's wrong with it.
A few months ago something popped in the system and I smelt a burning scent.
Diamond - Réponse
Bro,did it work for you?
I have same problem
EL cablemo -
I have same thing.
Erik Ferguson -
Just be careful when pulling up power supply on the left side facing you when Ps4 is upside-down.
jerrylaird3000 - Réponse
Oui c’est exactement ça j’ai arraché un câble.
Est-ce que quand je vais commander le bloc d’alimentation j’aurais j’aurai un autre ?
Fazel Slh -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 50
7 derniers jours : 323
30 derniers jours : 1,819
Total : 331,279
