Aller au contenu principal
PlayStation 4 Slim Fan System Replacement
Ce dont vous avez besoin
  1. PlayStation 4 Slim Fan System Replacement, Bottom Cover: étape 1, image 1 de 3 PlayStation 4 Slim Fan System Replacement, Bottom Cover: étape 1, image 2 de 3 PlayStation 4 Slim Fan System Replacement, Bottom Cover: étape 1, image 3 de 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Fan System Replacement: étape 2, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 2, image 2 de 2
    • Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Fan System Replacement: étape 3, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 3, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 3, image 3 de 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Fan System Replacement, Power Supply: étape 4, image 1 de 3 PlayStation 4 Slim Fan System Replacement, Power Supply: étape 4, image 2 de 3 PlayStation 4 Slim Fan System Replacement, Power Supply: étape 4, image 3 de 3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Fan System Replacement: étape 5, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 5, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 5, image 3 de 3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Fan System Replacement: étape 6, image 1 de 1
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Fan System Replacement: étape 7, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 7, image 2 de 2
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Fan System Replacement: étape 8, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 8, image 2 de 2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Fan System Replacement: étape 9, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 9, image 2 de 2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Fan System Replacement: étape 10, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 10, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 10, image 3 de 3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Fan System Replacement: étape 11, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 11, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 11, image 3 de 3
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
  12. PlayStation 4 Slim Fan System Replacement, Motherboard: étape 12, image 1 de 2 PlayStation 4 Slim Fan System Replacement, Motherboard: étape 12, image 2 de 2
    • Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
  13. PlayStation 4 Slim Fan System Replacement: étape 13, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 13, image 2 de 2
    • Locate the two wires connected to the bottom of the motherboard.
    • Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
  14. PlayStation 4 Slim Fan System Replacement: étape 14, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 14, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 14, image 3 de 3
    • Flip the device to the backside.
    • Unscrew and remove 14x (19x for CUH-21xx) 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 8x (7x for CUH-21xx) 6.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 4x 3.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
  15. PlayStation 4 Slim Fan System Replacement: étape 15, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 15, image 2 de 2
    • Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Skip this step for the CUH-21xx, as those screws were removed in the previous step.
  16. PlayStation 4 Slim Fan System Replacement: étape 16, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 16, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 16, image 3 de 3
    • Locate the white wire connected to the corner of the top of the motherboard.
    • Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
    • Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
  17. PlayStation 4 Slim Fan System Replacement: étape 17, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 17, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 17, image 3 de 3
    • Remove the connections by pulling out on the blue tabs with your fingers.
    • Flip up the black clip on the largest tab with your finger before removing it.
    • Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
  18. PlayStation 4 Slim Fan System Replacement: étape 18, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 18, image 2 de 2
    • Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself.
    • You may need to wiggle the plate a bit to get it loose before you lift it out.
    • Do not lose any of the black pads attached to the motherboard while performing this step.
  19. PlayStation 4 Slim Fan System Replacement: étape 19, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 19, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 19, image 3 de 3
    • Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Remove the small metal plate by grabbing it with your fingers and lifting up.
  20. PlayStation 4 Slim Fan System Replacement: étape 20, image 1 de 3 PlayStation 4 Slim Fan System Replacement: étape 20, image 2 de 3 PlayStation 4 Slim Fan System Replacement: étape 20, image 3 de 3
    • Remove this wire connection by firmly grasping it with tweezers and pulling out.
    • This might require a bit of force to disconnect, but be sure not to break any of the wires.
  21. PlayStation 4 Slim Fan System Replacement: étape 21, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 21, image 2 de 2
    • Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up.
    • You may need to wiggle the board a bit to get it loose before you remove it.
  22. PlayStation 4 Slim Fan System Replacement, Fan System: étape 22, image 1 de 2 PlayStation 4 Slim Fan System Replacement, Fan System: étape 22, image 2 de 2
    • Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion.
  23. PlayStation 4 Slim Fan System Replacement: étape 23, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 23, image 2 de 2
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
  24. PlayStation 4 Slim Fan System Replacement: étape 24, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 24, image 2 de 2
    • Unscrew and remove the two 40 mm screws using a PH00 screwdriver with a counter-clockwise motion.
  25. PlayStation 4 Slim Fan System Replacement: étape 25, image 1 de 2 PlayStation 4 Slim Fan System Replacement: étape 25, image 2 de 2
    • Remove the fan system by grabbing the edge of the top metal plate and lifting up with your hands.
64 autres ont terminé cette réparation.
Harry Koos
Membre depuis le 01/24/18
4 886 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S19-G4, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 membres
35 tutoriels rédigés
5 commentaires
Thank you so much for this guide! It was very helpful!
David Rodriguez - Réponse
Deine Schrauben großen machen gar kein Sinn du hast mehr verschiedene Schrauben als es gibt
Andre Hollmann - Réponse
My PS4 “Slim” is quite different internally than the one shown. But regardless, this guide is an excellent resource for us diy’ers. And don’t forget any parts when reassembling, like I did. Took four tries to get everything back where it belonged. And man, was it dusty in there! Regular cleaniings are a must.
Patrick Ogren - Réponse
My ps4 slim is different it has some extra parts, now I don’t know how to put it back, hahahahahhahaha
Lancelotte Fabros - Réponse
This guide gets you 90% of the way there. Some really important pieces are missing though, primarily:
- How you dont need to unplug the power supply cable from the motherboard, you can just unhook it from the plastic clips on the case.
- It never mentions cleaning the old Thermal Paste off the heatsink + cpu and replacing with a new dab.
Both of these are essential for a proper tear-down. If you dont replace the thermal paste, your PS4 is guaranteed to break down irreparably in the future. I had to know or discover them for myself. Please, please update this guide with that info.
Zoey Schlemper - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 69
7 derniers jours : 553
30 derniers jours : 2,267
Total : 131,642
