Introduction
Utilisez ce guide pour retirer ou remplacer l’alimentation de votre PlayStation 4 Slim.
Ce dont vous avez besoin
Localisez l'autocollant de garantie en plastique à côté des trois ports sur le côté de la console.
Retirez l'autocollant de garantie en le décollant avec tout type de spatule.
Dévissez et retirez la vis de 5,0 mm qui se trouvait derrière l'autocollant à l'aide d'un tournevis Torx de sécurité T8 avec un mouvement dans le sens antihoraire.
T8 fits like a glove for me
Is there anything else you can use
A small flathead screwdriver will work
There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
Nicholas -
There is a metal thing inside of the screw slot any insite on this?
Placez la Playstation 4 Slim à l'envers avec le côté de la vis que vous venez de retirer face à vous.
Soulevez les deux coins qui vous font face avec vos doigts.
Retirez le capot inférieur en le faisant glisser vers les coins arrière et en le soulevant.
It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
Placez la Playstation 4 Slim côté droit vers le haut, avec le logo PS en haut et le côté avec les mots "SONY" et "PS4" face à vous.
Retirez le capot supérieur en le faisant glisser vers les coins arrière et en le soulevant.
Dévissez et retirez les deux vis (une gauche 31,0 mm et une droite 24,0 mm) à l'aide d'un tournevis T8 avec un mouvement dans le sens antihoraire.
Dévissez et retirez la vis de 3,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
UK model seems to be different here. There's no Philips screw where there is on your image.
This regards EU models in general, i think. My danish version is the same.
Retirez les quatre vis Philips de 16 mm qui maintiennent le bloc d'alimentation en place.
Only 2 Phillips actress here on my UK
Only 2 phillips screws on the US one as well.
I also only have two screws here in the US.
Retirez la tôle métallique du dessus de l'alimentation en la saisissant et en la soulevant avec vos mains.
I think the metal sheet protects the rest of the console or something from heating too much.
Retirez l'antenne du haut de l'alimentation en guidant le fil avec vos doigts dans les rainures sous le panneau métallique.
What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
Me neither, guess they are different models.
Retournez la Playstation 4 Slim sur son dos.
Dévissez et retirez la vis de 4,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
How do you get it when the screw is stripped
Débranchez la connexion filaire de l'alimentation en la tenant fermement avec vos doigts ou une pince à épiler et en la tirant.
Retirez complètement l'alimentation en saisissant et en soulevant avec vos mains.
Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
Misha FV -
You are right, pulling the wires is entirely wrong. I used the small rectangular, thin blue plastic to push the cable back from the socket. It was too tight. From my experience of repairing, never pull wires. The consequences of damaging it are not worth it.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
70 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
6 commentaires
My PS4 not turning on
This was awesome. Thanks for the assist
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
My PS4 runs for 10 minutes and turns off again and again
I really appreciate this help hopefully this doesn't damage my PS4
Remove the screw directly to the left of that one in the picture as well. Should be silver.
Elizabeth Johnson - Réponse
ihr seid so ein scheiß haufen das stimmt über haubt nix
Toaster 95 - Réponse
einfach alles stimmt nicht
