Introduction
Consoles such as the PlayStation 4 Slim over time start to overheat from all the excessive dust accumulating. It causes the thermal paste to thin out and the speed drastically reduces. The overheating produces noise and users no longer want the console because of this some are even willing to replace it. This guide shows how to clean PlayStation 4 Slim, replace the thermal paste, and restore the console to fantastic working conditions!
Ce dont vous avez besoin
Vidéo d'introduction
Remove the panel next to the ports by sliding it to the right.
Use a Philips PH1 screwdriver to remove the screw.
Flip the PS4 to view the metal paneling.
Lift the black clip on the largest connection to remove it.
Disconnect the wire by pulling it back with a little bit of force.
By pulling on the blue tabs gently you are able to remove the connections.
Gently lift the black wire to disconnect from the motherboard.
73 autres ont terminé cette réparation.
11 commentaires
the original fat ps4 uses a different design than the slim one
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Thanks for the instructions, they helped me a lot!!! If there's one thing Sony didn't save on this console, it was screws 😂😂😂
La guía es muy fácil de seguir y los resultados superaron mis expectativas, la falla de recalentamiento ya no aparece más. Gracias!!
