Aller au contenu principal
PlayStation 5 Faceplate Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. PlayStation 5 Faceplate Replacement, Faceplate: étape 1, image 1 de 3 PlayStation 5 Faceplate Replacement, Faceplate: étape 1, image 2 de 3 PlayStation 5 Faceplate Replacement, Faceplate: étape 1, image 3 de 3
    • Make sure the PS5 console is turned off, and no wires are connected to the ports.
    • Place the PS5 console horizontally with the PlayStation logo facing upfront.
    • Use a soft work surface to protect the device.
  2. PlayStation 5 Faceplate Replacement: étape 2, image 1 de 2 PlayStation 5 Faceplate Replacement: étape 2, image 2 de 2
    • Remove the PS5 stand from the console by unscrewing a slotted flat head screw located at the bottom of the stand with a slotted screwdriver.
  3. PlayStation 5 Faceplate Replacement: étape 3, image 1 de 2 PlayStation 5 Faceplate Replacement: étape 3, image 2 de 2
    • After unscrewing, use your hand to lift the PS5 console from one side.
    • Use your other hand to remove the PS5 stand.
  4. PlayStation 5 Faceplate Replacement: étape 4, image 1 de 3 PlayStation 5 Faceplate Replacement: étape 4, image 2 de 3 PlayStation 5 Faceplate Replacement: étape 4, image 3 de 3
    • Using your fingers, pull the side plate upwards from the corner of the PlayStation logo.
    • While pulling up the side plate, use your other hand on the opposite corner of the PlayStation logo to push the side plate down until you hear a click sound.
    • Remove the side plate from the PS5 console.
  5. PlayStation 5 Faceplate Replacement: étape 5, image 1 de 3 PlayStation 5 Faceplate Replacement: étape 5, image 2 de 3 PlayStation 5 Faceplate Replacement: étape 5, image 3 de 3
    • Flip the PS5 console over with its rear ports facing towards you.
  6. PlayStation 5 Faceplate Replacement: étape 6, image 1 de 3 PlayStation 5 Faceplate Replacement: étape 6, image 2 de 3 PlayStation 5 Faceplate Replacement: étape 6, image 3 de 3
    • Using your fingers, pull up the faceplate from the bottom right corner while using your other hand at the opposite corner to push the side plate downwards.
    • Attempt this until you hear a click sound.
  7. PlayStation 5 Faceplate Replacement: étape 7, image 1 de 2 PlayStation 5 Faceplate Replacement: étape 7, image 2 de 2
    • Put the new side plate on by placing it on top of the console and aligning its hooks with its corresponding holes.
    • Use your hand to push the plate from the bottom while pulling up one of the corners of the side plate on the opposite side.
    • Repeat the previous step for the other side plate.
Syed Asif
Membre depuis le 09/07/21
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-2, O'Regan Fall 2021 Membre de l'équipe York University, Team 1-2, O'Regan Fall 2021
YORK-O'REGAN-F21S1G2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 501
