Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
  1. Remove all cables plugged into the PlayStation.
    • Remove all cables plugged into the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Flip the PlayStation back.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  5. Lift up and remove the upper case. Lift up and remove the upper case.
    • Lift up and remove the upper case.
  6. Disconnect the ribbon cable and wired cable connectors. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
    • Disconnect the ribbon cable and wired cable connectors.
    • Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
  7. remove the metal plate remove the metal plate
    • remove the metal plate
  8. remove the mother board by lifting the back. if you're having a hard time removing it, use your nail and lift the second controller port. if you're having a hard time removing it, use your nail and lift the second controller port.
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  9. Remove the metal case. Remove the metal case.
    • Remove the metal case.
3 autre(s) ont terminé cette réparation.
trickster
Membre depuis le 23/12/2013
1 941 Réputation
11 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 16
Total : 1,612
