Aller au contenu principal
PlayStation One Lower Case Replacement
Ce dont vous avez besoin
  1. PlayStation One Lower Case Replacement, Upper Case: étape 1, image 1 de 1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Lower Case Replacement: étape 2, image 1 de 2 PlayStation One Lower Case Replacement: étape 2, image 2 de 2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Lower Case Replacement: étape 3, image 1 de 1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Lower Case Replacement: étape 4, image 1 de 2 PlayStation One Lower Case Replacement: étape 4, image 2 de 2
    • Lift up and remove the upper case.
  5. PlayStation One Lower Case Replacement, Laser Assembly: étape 5, image 1 de 3 PlayStation One Lower Case Replacement, Laser Assembly: étape 5, image 2 de 3 PlayStation One Lower Case Replacement, Laser Assembly: étape 5, image 3 de 3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Lower Case Replacement, Mother Board: étape 6, image 1 de 2 PlayStation One Lower Case Replacement, Mother Board: étape 6, image 2 de 2
    • remove the metal plate
  7. PlayStation One Lower Case Replacement: étape 7, image 1 de 3 PlayStation One Lower Case Replacement: étape 7, image 2 de 3 PlayStation One Lower Case Replacement: étape 7, image 3 de 3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  8. PlayStation One Lower Case Replacement, Lower Case: étape 8, image 1 de 2 PlayStation One Lower Case Replacement, Lower Case: étape 8, image 2 de 2
    • Remove the metal case.
5 autres ont terminé cette réparation.
Marjorie
Membre depuis le 12/23/13
2 273 Réputation
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 57
Total : 3,994
