Aller au contenu principal
  1. Place psvr hub with IO facing up Peel sticker up with a fingernail or a pry tool
    • Place psvr hub with IO facing up
    • Peel sticker up with a fingernail or a pry tool
    • Remove the single J0 screw
    • Place the screw in a part tray to keep it organized.
  2. Use a opening tool to separate bottom from the top. Use a opening tool to separate bottom from the top. Use a opening tool to separate bottom from the top.
    • Use a opening tool to separate bottom from the top.
  3. Remove the 8 J0 screws Place the screws in the parts tray Use your tweezers to disconnect the fan connector from the motherboard
    • Remove the 8 J0 screws
    • Place the screws in the parts tray
    • Use your tweezers to disconnect the fan connector from the motherboard
    • if fan needs to be replaced stop here and follow in reverse.
    • Fan details.
    • Brand: Nidec
    • Model and dimensions: U35x05m 52aa7-56j14
    • Power: 5v and .18a
  4. Use a spudger or a fingernail to lift the pcb in the direction highlighted Gently separate the metal plate from pcb Replace the thermal paste if needed.
    • Use a spudger or a fingernail to lift the pcb in the direction highlighted
    • Gently separate the metal plate from pcb
    • Replace the thermal paste if needed.
    • Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
Kalib Ellery
Membre depuis le 17/10/2016
399 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 12
30 derniers jours : 36
Total : 231
