Introduction
This guide takes you through the process of installing the rear panel. The rear panel houses the rear touch pad.
Ce dont vous avez besoin
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
Slide the spuder between the right speaker and the rear casing.
Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
Remove the right speaker.
11 autres ont terminé cette réparation.
5 commentaires
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Those are wifi antennas. You can get it out put it in to the new panel.
