Aller au contenu principal
PlayStation Vita Right Joystick Replacement
Ce dont vous avez besoin
  1. PlayStation Vita Right Joystick Replacement, Case Separation: étape 1, image 1 de 2 PlayStation Vita Right Joystick Replacement, Case Separation: étape 1, image 2 de 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Joystick Replacement: étape 2, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 2, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 2, image 3 de 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Joystick Replacement: étape 3, image 1 de 2 PlayStation Vita Right Joystick Replacement: étape 3, image 2 de 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Joystick Replacement: étape 4, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 4, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 4, image 3 de 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Joystick Replacement: étape 5, image 1 de 2 PlayStation Vita Right Joystick Replacement: étape 5, image 2 de 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Joystick Replacement: étape 6, image 1 de 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Joystick Replacement: étape 7, image 1 de 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Joystick Replacement: étape 8, image 1 de 1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Joystick Replacement, Wireless Card: étape 9, image 1 de 3 PlayStation Vita Right Joystick Replacement, Wireless Card: étape 9, image 2 de 3 PlayStation Vita Right Joystick Replacement, Wireless Card: étape 9, image 3 de 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Joystick Replacement: étape 10, image 1 de 2 PlayStation Vita Right Joystick Replacement: étape 10, image 2 de 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Joystick Replacement: étape 11, image 1 de 2 PlayStation Vita Right Joystick Replacement: étape 11, image 2 de 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Joystick Replacement, Right Shoulder Button: étape 12, image 1 de 3 PlayStation Vita Right Joystick Replacement, Right Shoulder Button: étape 12, image 2 de 3 PlayStation Vita Right Joystick Replacement, Right Shoulder Button: étape 12, image 3 de 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Joystick Replacement: étape 13, image 1 de 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Joystick Replacement: étape 14, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 14, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 14, image 3 de 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Joystick Replacement: étape 15, image 1 de 2 PlayStation Vita Right Joystick Replacement: étape 15, image 2 de 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Joystick Replacement, Right Button Board: étape 16, image 1 de 2 PlayStation Vita Right Joystick Replacement, Right Button Board: étape 16, image 2 de 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Joystick Replacement: étape 17, image 1 de 2 PlayStation Vita Right Joystick Replacement: étape 17, image 2 de 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Joystick Replacement: étape 18, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 18, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 18, image 3 de 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Joystick Replacement: étape 19, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 19, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 19, image 3 de 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Joystick Replacement: étape 20, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 20, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 20, image 3 de 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Right Joystick Replacement, Right Joystick: étape 21, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the two 5.0mm, blue screws from the right joystick.
  22. PlayStation Vita Right Joystick Replacement: étape 22, image 1 de 3 PlayStation Vita Right Joystick Replacement: étape 22, image 2 de 3 PlayStation Vita Right Joystick Replacement: étape 22, image 3 de 3
    • Using a spudger, gently pry the joystick out of the back casing assembly.
25 autres ont terminé cette réparation.
Brittany McCrigler
Membre depuis le 03/05/12
89 011 Réputation
131 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 734 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 25
30 derniers jours : 138
Total : 29,164
