Introduction
This guide takes you through installing the SIM card reader on the PlayStation Vita.
Ce dont vous avez besoin
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Free the battery cable by gently prying up on the connection with a spudger.
Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
Yea I messed up there too. Is there a way to fix it?
This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
broke the white part
Gently pry open the tab of the flex cable socket on top of the SIM card reader.
Free the flex cable by sliding the spudger underneath it and pulling it out of the socket. Rest the flex cable out of the way.
Un commentaire
I have an error relating to the reader on my Vita. If I took it out without replacing it, will it cause the same or different error so I have to replace it, or will it be (somewhat) fine??
