Aller au contenu principal
Playstation 3 Optical Drive Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Playstation 3 Optical Drive Replacement, Top Cover: étape 1, image 1 de 2 Playstation 3 Optical Drive Replacement, Top Cover: étape 1, image 2 de 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Optical Drive Replacement: étape 2, image 1 de 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Optical Drive Replacement: étape 3, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 3, image 2 de 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Optical Drive Replacement: étape 4, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 4, image 2 de 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Optical Drive Replacement: étape 5, image 1 de 3 Playstation 3 Optical Drive Replacement: étape 5, image 2 de 3 Playstation 3 Optical Drive Replacement: étape 5, image 3 de 3
    • You can now lift off the top cover.
  6. Playstation 3 Optical Drive Replacement, Optical Drive: étape 6, image 1 de 3 Playstation 3 Optical Drive Replacement, Optical Drive: étape 6, image 2 de 3 Playstation 3 Optical Drive Replacement, Optical Drive: étape 6, image 3 de 3
    • Lift the optical drive enclosure and disconnect the grey wires.
    • Do not lift it too far up before disconnecting the wires.
  7. Playstation 3 Optical Drive Replacement: étape 7, image 1 de 3 Playstation 3 Optical Drive Replacement: étape 7, image 2 de 3 Playstation 3 Optical Drive Replacement: étape 7, image 3 de 3
    • Tilt the front of the optical drive enslosure upwards.
    • Lift the black ribbon cable latch on the back side with your finger or a spudger.
    • Disconnect the ribbon cable.
  8. Playstation 3 Optical Drive Replacement: étape 8, image 1 de 1
    • Remove the optical drive enclosure from the PS3.
  9. Playstation 3 Optical Drive Replacement: étape 9, image 1 de 3 Playstation 3 Optical Drive Replacement: étape 9, image 2 de 3 Playstation 3 Optical Drive Replacement: étape 9, image 3 de 3
    • Flip over the optical drive enclosure. There are four ribbon cables connected to the circuit board. Using a spudger or your finger, lift each ribbon cable latch and disconnect each ribbon cable.
    • Remove the three screws on the board with a Phillips #00 screwdriver.
    • Remove the two silver screws on the bottom of the case. These screws are different from the ones on the board and should be kept separate.
    • Note: The longer of these two screws holds down a metal tab that comes loose as seen in the third picture.
  10. Playstation 3 Optical Drive Replacement: étape 10, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 10, image 2 de 2
    • Using your thumbs, carefully bend out the sides of the metal enclosure.
    • Lift the plastic enclosure out of the metal enclosure.
  11. Playstation 3 Optical Drive Replacement: étape 11, image 1 de 3 Playstation 3 Optical Drive Replacement: étape 11, image 2 de 3 Playstation 3 Optical Drive Replacement: étape 11, image 3 de 3
    • Flip over the enclosure so that the circuit board is on the bottom and the optical sensor is on top.
    • Remove the screw on the optical sensor using a Phillips #00 screwdriver.
    • Remove the tape on the red and black wires that connect to the optical sensor. With the wires still attached, take the sensor off the ensclosure.
    • The wires on the optical sensor are very weak. They will break easily if excessive force is applied to them.
    • Remove the four black screws on the edges of the enclosure using a Phillips #00 screwdriver.
    • After taking out the screws, you don't have to open the enclosure just yet.
  12. Playstation 3 Optical Drive Replacement: étape 12, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 12, image 2 de 2
    • Flip over the enclosure again.
    • Remove the rest of the screws in the corners of the circuit board.
  13. Playstation 3 Optical Drive Replacement: étape 13, image 1 de 3 Playstation 3 Optical Drive Replacement: étape 13, image 2 de 3 Playstation 3 Optical Drive Replacement: étape 13, image 3 de 3
    • Lift the circuit board off the enclosure.
    • The metal EM shield on the circuit board is loose, so make sure to keep it together with the circuit board.
    • Remove the metal plate.
  14. Playstation 3 Optical Drive Replacement: étape 14, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 14, image 2 de 2
    • Flip over the enclosure. Remove the black, plastic cover so that the drive and its enclosure match the first picture.
    • Proceed carefully. There are loose parts inside the optical drive. We recommend that you tape these parts.
  15. Playstation 3 Optical Drive Replacement: étape 15, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 15, image 2 de 2
    • Using a spudger, lift the brown latch and disconnect the small ribbon cable.
    • Remove the four fat screws in the corners of the optical drive.
    • Using a spudger, lift the black latch and disconnect the larger ribbon cable.
  16. Playstation 3 Optical Drive Replacement: étape 16, image 1 de 2 Playstation 3 Optical Drive Replacement: étape 16, image 2 de 2
    • Carefully lift the optical drive out of the enclosure.
2 autres ont terminé cette réparation.
iDeleted
Membre depuis le 07/07/10
2 101 Réputation
39 tutoriels rédigés
Un commentaire
When reassembling it there is a key part that needs to be exactly inline. see this video for help: http://www.youtube.com/watch?v=hzHPRGHFj...
Paddy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 7,421
