Aller au contenu principal
Plum Optimax 10 Headphone Jack Replacement
Ce dont vous avez besoin
  1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: étape 1, image 1 de 2 Plum Optimax 10 Headphone Jack  Replacement, Back Cover: étape 1, image 2 de 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Headphone Jack  Replacement: étape 2, image 1 de 2 Plum Optimax 10 Headphone Jack  Replacement: étape 2, image 2 de 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: étape 3, image 1 de 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: étape 3, image 2 de 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: étape 3, image 3 de 3
    • Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
    • Use a plastic opening tool to pry up the headphone jack from its place in the case.
    • The headphone jack is lightly adhered to the back case.
    • When removing the jack, be gentle with the ribbon wire because it is capable of tearing.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 82
