Aller au contenu principal
Pneumatic Door Closer Replacement
Ce dont vous avez besoin
  1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: étape 1, image 1 de 2 Pneumatic Door Closer Replacement, Pneumatic Door Closer: étape 1, image 2 de 2
    • Identify the broken part of the door.
  2. Pneumatic Door Closer Replacement: étape 2, image 1 de 2 Pneumatic Door Closer Replacement: étape 2, image 2 de 2
    • Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
  3. Pneumatic Door Closer Replacement: étape 3, image 1 de 3 Pneumatic Door Closer Replacement: étape 3, image 2 de 3 Pneumatic Door Closer Replacement: étape 3, image 3 de 3
    • Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
  4. Pneumatic Door Closer Replacement: étape 4, image 1 de 2 Pneumatic Door Closer Replacement: étape 4, image 2 de 2
    • Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
  5. Pneumatic Door Closer Replacement: étape 5, image 1 de 3 Pneumatic Door Closer Replacement: étape 5, image 2 de 3 Pneumatic Door Closer Replacement: étape 5, image 3 de 3
    • Plug the smallest included screw into the inner bracket to attach the door closer.
  6. Pneumatic Door Closer Replacement: étape 6, image 1 de 3 Pneumatic Door Closer Replacement: étape 6, image 2 de 3 Pneumatic Door Closer Replacement: étape 6, image 3 de 3
    • Close the door.
    • Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
  7. Pneumatic Door Closer Replacement: étape 7, image 1 de 3 Pneumatic Door Closer Replacement: étape 7, image 2 de 3 Pneumatic Door Closer Replacement: étape 7, image 3 de 3
    • Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
  8. Pneumatic Door Closer Replacement: étape 8, image 1 de 2 Pneumatic Door Closer Replacement: étape 8, image 2 de 2
    • Make sure the door closes and opens properly.
    • Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
Ligne d'arrivée
Abdullah Kaddura
Membre depuis le 02/24/21
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 26
Total : 580
