Aller au contenu principal
Polar M400 Watch micro-USB connector Replacement
Ce dont vous avez besoin
  1. Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: étape 1, image 1 de 3 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: étape 1, image 2 de 3 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: étape 1, image 3 de 3
    • Follow the screen replacement tutorial to dismantle the watch.
    • Carefully lift the screen from the board.
    • Disconnect the USB's flex PCB from the main board. Save the red rubber seal of the USB connector for later.
    • Use a tool like a helping hand to hold the USB connector part.
    • Using a heat gun, blow hot air underneath the PCB.
    • Once the solder is melting give the connector a good tap in order to make the PCB fall loose.
  2. Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: étape 3, image 1 de 2 Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: étape 3, image 2 de 2
    • Place the new USB connector on a flat surface with its pins pointing upwards.
    • Place the PCB on top on the pins, the exposed copper traces on the flex PCB facing the flat surface.
    • Using an iron, solder the PCB by heating all the pads at the same time (as much as possible) and apply pressure so that the pins of the USB connector come through.
  3. Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: étape 4, image 1 de 2 Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: étape 4, image 2 de 2
    • Connect the flex PCB back to the main board.
    • Reassemble the watch stopping before screwing the lid back.
    • Add hot glue to the base of the USB connector filling the watch case's cavity. Be careful not to put hot glue inside the connector.
    • While the glue is still hot, put the red rubber seal back on top.
    • Screw the lid back.
6 autres ont terminé cette réparation.
Benjamin Freeman
Membre depuis le 01/16/20
289 Réputation
1 tutoriel rédigé
10 commentaires
Sehr gute Beschreibung,
aber ich finde keine USB-Buchse für die M400 zu kaufen
Wo gibt's die Teile?
martinmartinez644 - Réponse
Danke schön. Für den Konnektor allein habe ich auf Aliexpress gekauft : https://www.aliexpress.com/item/32960430...
Benjamin Freeman -
From where do I order usb connector?
Pankaj Singh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 55
30 derniers jours : 290
Total : 16,784
