Introduction
This guide will show how to replace the charging port cover of the Polar V800 sports watch. Replacement may be needed if the charging port cover wears out from use or if the charging port cover breaks off. The charging port cover provides the charging port with much need protection from the elements to avoid corrosion and residue build-up.
Ce dont vous avez besoin
Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
Completely pull out the pins.
