Aller au contenu principal
Polaroid Cube Battery Replacement
Ce dont vous avez besoin
  1. Polaroid Cube Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Battery Replacement: étape 2, image 1 de 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Battery Replacement: étape 3, image 1 de 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Battery Replacement: étape 4, image 1 de 2 Polaroid Cube Battery Replacement: étape 4, image 2 de 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Battery Replacement: étape 5, image 1 de 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Battery Replacement: étape 6, image 1 de 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Battery Replacement: étape 7, image 1 de 2 Polaroid Cube Battery Replacement: étape 7, image 2 de 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Battery Replacement: étape 8, image 1 de 3 Polaroid Cube Battery Replacement: étape 8, image 2 de 3 Polaroid Cube Battery Replacement: étape 8, image 3 de 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Battery Replacement: étape 9, image 1 de 2 Polaroid Cube Battery Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Battery Replacement: étape 10, image 1 de 1
    • Gently remove the battery pin connector from the circuit board.
10 autres ont terminé cette réparation.
heath lamkin
Membre depuis le 09/29/16
372 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-2, Harley Fall 2016 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 membres
3 tutoriels rédigés
13 commentaires
Any idea where to find the replacement batteries?
hooverhogg - Réponse
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - Réponse
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor -
Was anyone able to to find the replacement batteries for the Cube?
yzorger - Réponse
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 9,175
