Aller au contenu principal
Polaroid Cube Lens Replacement
Ce dont vous avez besoin
  1. Polaroid Cube Lens Replacement, Battery: étape 1, image 1 de 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: étape 2, image 1 de 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: étape 3, image 1 de 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: étape 4, image 1 de 2 Polaroid Cube Lens Replacement: étape 4, image 2 de 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: étape 5, image 1 de 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: étape 6, image 1 de 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: étape 7, image 1 de 2 Polaroid Cube Lens Replacement: étape 7, image 2 de 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: étape 8, image 1 de 3 Polaroid Cube Lens Replacement: étape 8, image 2 de 3 Polaroid Cube Lens Replacement: étape 8, image 3 de 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: étape 9, image 1 de 2 Polaroid Cube Lens Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: étape 10, image 1 de 1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: étape 11, image 1 de 2 Polaroid Cube Lens Replacement, Lens: étape 11, image 2 de 2
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: étape 12, image 1 de 2 Polaroid Cube Lens Replacement: étape 12, image 2 de 2
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: étape 13, image 1 de 1
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
4 autres ont terminé cette réparation.
Grant Baldwin
Membre depuis le 09/29/16
685 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2016 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 membres
3 tutoriels rédigés
2 commentaires
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - Réponse
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 36
Total : 2,309
