Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Polaroid Cube Video Quality Switch Replacement
Ce dont vous avez besoin
  1. Polaroid Cube Video Quality Switch Replacement, Battery: étape 1, image 1 de 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
    Demander à FixBot
    Ajouter un commentaire
  2. Polaroid Cube Video Quality Switch Replacement: étape 2, image 1 de 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
    Demander à FixBot
  3. Polaroid Cube Video Quality Switch Replacement: étape 3, image 1 de 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
    Demander à FixBot
  4. Polaroid Cube Video Quality Switch Replacement: étape 4, image 1 de 2 Polaroid Cube Video Quality Switch Replacement: étape 4, image 2 de 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
    Demander à FixBot
  5. Polaroid Cube Video Quality Switch Replacement: étape 5, image 1 de 1
    • Remove shell from top and bottom of camera.
    Demander à FixBot
  6. Polaroid Cube Video Quality Switch Replacement: étape 6, image 1 de 1
    • Remove the rubber seal wrapped around the camera.
    Demander à FixBot
  7. Polaroid Cube Video Quality Switch Replacement: étape 7, image 1 de 2 Polaroid Cube Video Quality Switch Replacement: étape 7, image 2 de 2
    • Remove the tape wrapped around the battery.
    Demander à FixBot
  8. Polaroid Cube Video Quality Switch Replacement: étape 8, image 1 de 3 Polaroid Cube Video Quality Switch Replacement: étape 8, image 2 de 3 Polaroid Cube Video Quality Switch Replacement: étape 8, image 3 de 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
    Demander à FixBot
  9. Polaroid Cube Video Quality Switch Replacement: étape 9, image 1 de 2 Polaroid Cube Video Quality Switch Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
    Demander à FixBot
  10. Polaroid Cube Video Quality Switch Replacement: étape 10, image 1 de 1
    • Gently remove the battery pin connector from the circuit board.
    Demander à FixBot
  11. Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: étape 11, image 1 de 2 Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: étape 11, image 2 de 2
    • Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
    Demander à FixBot
  12. Polaroid Cube Video Quality Switch Replacement: étape 12, image 1 de 1
    • Remove the circuit board.
    Demander à FixBot
  13. Polaroid Cube Video Quality Switch Replacement: étape 13, image 1 de 2 Polaroid Cube Video Quality Switch Replacement: étape 13, image 2 de 2
    • Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
    • Remove and replace the broken video quality switch.
    Demander à FixBot
4 autres ont terminé cette réparation.
Grant Baldwin
Membre depuis le 09/29/16
685 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2016 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 34
Total : 1,209
