Introduction
If you need to replace the lens this is guide will allow you to do so. You may need to replace the lens if it becomes scratched or cracked. For this replacement guide you will need to use the Shutter Switch replacement guide steps 1-4 as a precursor guide.
Ce dont vous avez besoin
Unscrew the four Phillips #0 5 mm screws on the base of the camera.
Remove the two pieces of the base.
2 autres ont terminé cette réparation.
