Aller au contenu principal
Polaroid Onestep Close Up Forward Viewfinder Replacement
Ce dont vous avez besoin
  1. Polaroid Onestep Close Up Forward Viewfinder Replacement, Flash Assembly Removal: étape 1, image 1 de 3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Flash Assembly Removal: étape 1, image 2 de 3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Flash Assembly Removal: étape 1, image 3 de 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Forward Viewfinder Replacement, Opening Film Tray: étape 2, image 1 de 2 Polaroid Onestep Close Up Forward Viewfinder Replacement, Opening Film Tray: étape 2, image 2 de 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing Face Plate: étape 3, image 1 de 3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing Face Plate: étape 3, image 2 de 3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing Face Plate: étape 3, image 3 de 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Slider: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Once you have the face plate removed the first thing to do is pry off the slider (the light grey bar near the bottom). The easiest way to accomplish this is to place the tweezers where the red circles are to pop the piece out.
  5. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Face Plate: étape 5, image 1 de 3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Face Plate: étape 5, image 2 de 3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Face Plate: étape 5, image 3 de 3
    • Use the tweezers at the locations shown in the first two pictures to remove the face plate shown in the third picture.
    • This is a pretty secure fit in most cases so it might take a bit of tinkering to get the plate to pop off.
  6. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Forward Viewfinder: étape 6, image 1 de 1
    • With the plate removed the lens should be easy enough to pop out.
    • If you don't want to dirty the lens it would be best to put on gloves or handle the lens with a rag of some kind.
Jordan
Membre depuis le 09/22/14
471 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 1,435
