Introduction
This process requires soldering and lots of smelly adhesive. For more information about soldering, take a look at this guide. Be careful, as a ruptured battery can be dangerous.
Ce dont vous avez besoin
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning them counterclockwise.
Outil utilisé dans cette étape :Plastic Cards$2.99
Wedge a plastic card beneath the battery unit.
Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Set the device on a heat safe surface.
Desolder from the motherboard the red wire that connects to the battery unit.
Desolder from the motherboard the black wire that connects to the battery unit.
Lift the battery out of the device using your hands.
The battery is now free from the device.
4 autres ont terminé cette réparation.
Un commentaire
This tablet has the exact same setup as the 2011-2012 nextbook part might be interchangeable with this tablet .
