Aller au contenu principal
Polaroid Sun 600 LMS Lens Replacement
Ce dont vous avez besoin
  1. Polaroid Sun 600 LMS Lens Replacement, Lens: étape 1, image 1 de 2 Polaroid Sun 600 LMS Lens Replacement, Lens: étape 1, image 2 de 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Polaroid Sun 600 LMS Lens Replacement: étape 2, image 1 de 2 Polaroid Sun 600 LMS Lens Replacement: étape 2, image 2 de 2
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
  3. Polaroid Sun 600 LMS Lens Replacement: étape 3, image 1 de 2 Polaroid Sun 600 LMS Lens Replacement: étape 3, image 2 de 2
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
  4. Polaroid Sun 600 LMS Lens Replacement: étape 4, image 1 de 2 Polaroid Sun 600 LMS Lens Replacement: étape 4, image 2 de 2
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
  5. Polaroid Sun 600 LMS Lens Replacement: étape 5, image 1 de 2 Polaroid Sun 600 LMS Lens Replacement: étape 5, image 2 de 2
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
  6. Polaroid Sun 600 LMS Lens Replacement: étape 6, image 1 de 2 Polaroid Sun 600 LMS Lens Replacement: étape 6, image 2 de 2
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
Ian Hosek
Membre depuis le 01/20/10
357 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-18, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 31
Total : 10,546
