Aller au contenu principal
Introduction
When the screen on your camera breaks, it becomes almost completely unusable. This guide will show you how to replace the LCD screen on a Polaroid i533 camera.
Pièces
Aucune pièce spécifiée.
  1. Remove the four 3mm screws from the left-hand side of the camera screen. On the right-hand side of the camera screen, unscrew and remove the two 3mm screws. On the bottom of the camera, unscrew and remove the three 3mm screws.
    • Remove the four 3mm screws from the left-hand side of the camera screen.
    • On the right-hand side of the camera screen, unscrew and remove the two 3mm screws.
    • On the bottom of the camera, unscrew and remove the three 3mm screws.
  2. Slide the battery door open and slightly open the side of the case with a plastic opening tool.
    • Slide the battery door open and slightly open the side of the case with a plastic opening tool.
  3. Be careful not to pull the cover off completely, as it should remain attached to the motherboard.
    • Be careful not to pull the cover off completely, as it should remain attached to the motherboard.
    • Gently pull the cover away from the rest of the camera. Do not separate the pieces completely.
  4. Locate where the LCD screen ribbon is attached to the logic board. Using the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the motherboard.
    • Locate where the LCD screen ribbon is attached to the logic board.
    • Using the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the motherboard.
  5. Gently pull the ribbon away from the motherboard. This will allow the cover to separate from the rest of the camera.
    • Gently pull the ribbon away from the motherboard. This will allow the cover to separate from the rest of the camera.
  6. Locate the four screws in each corner of the LCD screen and carefully remove them. After they have been removed, ensure the screws stay separate from the 3mm case screws.
    • Locate the four screws in each corner of the LCD screen and carefully remove them. After they have been removed, ensure the screws stay separate from the 3mm case screws.
  7. Remove the LCD screen from the remaining casing of the camera.
    • Remove the LCD screen from the remaining casing of the camera.
ashley
Membre depuis le 24/06/2010
19 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-4, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 membres
8 tutoriels rédigés
Un commentaire
great job and information
John Webb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 3,529
