Aller au contenu principal
Polk MagniFi Soundbar Internal Power Adapter Replacement
Ce dont vous avez besoin
  1. Polk MagniFi Soundbar Internal Power Adapter Replacement, Internal Power Adapter: étape 1, image 1 de 1
    • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips' head in size J1.
    • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed. This will be shown in the next step.
    • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
  2. Polk MagniFi Soundbar Internal Power Adapter Replacement: étape 2, image 1 de 2 Polk MagniFi Soundbar Internal Power Adapter Replacement: étape 2, image 2 de 2
    • Underneath the back cover, there will be two flat panels, each with two 1cm screws.
    • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
  3. Polk MagniFi Soundbar Internal Power Adapter Replacement: étape 3, image 1 de 2 Polk MagniFi Soundbar Internal Power Adapter Replacement: étape 3, image 2 de 2
    • To detach the cables grab the internal power adapter in one hand and with the other grab the base of the wires and firmly pull them straight out from the device.
5 autres ont terminé cette réparation.
[deleted]
Membre depuis le 10/22/18
671 Réputation
4 tutoriels rédigés
2 commentaires
where do you get the motherboard for this soundbar?
Tim - Réponse
Where do we get replacement part?
Leon Haddrell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 27
Total : 2,371
