Aller au contenu principal
Porter Cable 690LR Base Panel Replacement
Ce dont vous avez besoin
  1. Porter Cable 690LR Base Panel Replacement, Base: étape 1, image 1 de 2 Porter Cable 690LR Base Panel Replacement, Base: étape 1, image 2 de 2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Panel Replacement: étape 2, image 1 de 2 Porter Cable 690LR Base Panel Replacement: étape 2, image 2 de 2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Panel Replacement, Base Panel: étape 3, image 1 de 2 Porter Cable 690LR Base Panel Replacement, Base Panel: étape 3, image 2 de 2
    • Orient the base so the black circular plate is facing you. Locate the three silver screw heads.
    • Use a flathead screwdriver to take off the three 10 mm screws.
Emma Stine
Membre depuis le 10/06/16
273 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-7, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 membres
6 tutoriels rédigés
Un commentaire
Aynı ürünü kullanıyorum..! Son birkaç yıldır Porter Cable ürünlerini kullanıyorum
Ancak bunu bu siteden satın aldım - https://www.raptorsupplies.com/b/porter-...
Omer Polat - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 190
