Aller au contenu principal
Porter Cable 690LR Power Switch Replacement
Ce dont vous avez besoin
  1. Porter Cable 690LR Power Switch Replacement, Power Switch: étape 1, image 1 de 2 Porter Cable 690LR Power Switch Replacement, Power Switch: étape 1, image 2 de 2
    • Use a Torx screwdriver to unscrew the 25.4 mm screws found at the top of the model.
  2. Porter Cable 690LR Power Switch Replacement: étape 2, image 1 de 2 Porter Cable 690LR Power Switch Replacement: étape 2, image 2 de 2
    • Remove the top by gently lifting the cover from router body.
    • Be careful when pulling the top from its place; wires connect the switch to the electrical cord and could be pulled loose or damaged.
  3. Porter Cable 690LR Power Switch Replacement: étape 3, image 1 de 1
    • Use a spudger to pull off the plastic covering of the power switch.
    • Don’t be afraid to really pry underneath the plastic (no components of the router will be damaged if you do so).
  4. Porter Cable 690LR Power Switch Replacement: étape 4, image 1 de 1
    • Push the power switch through the top of the router. The power switch should now be completely detached from the router (besides the wire connections).
  5. Porter Cable 690LR Power Switch Replacement: étape 5, image 1 de 2 Porter Cable 690LR Power Switch Replacement: étape 5, image 2 de 2
    • Find the wire plugs which are attached to the power switch. These connections are located at the back of the plastic box that houses the switch.
    • Use the spudger to carefully loosen the metal and rubber coverings, and detach the connections from the switch.
    • While some force is needed in order to successfully pull the connections free, have care in making sure that you don’t damage any of the metal components. If needed you may carefully use a metal spudger instead of a plastic opening tool.
2 autres ont terminé cette réparation.
Jaymes Ullrich
Membre depuis le 10/05/16
343 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 20-7, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 857
